112 Extreme
112 Extreme
Weld, Cut & Grommet Long Straight Seams
The 112 Extreme high-performance welder is our fastest and most precise welder for long straight seams. With speeds up to 20M / minute, this machine is able to handle fabric seals quickly and efficiently, ultimately saving you time and money. The 112 Extreme can be built to any size length you need!
- Aerospace
- Athletic Mats
- Awnings
- Banners
- Billboards
- Clear Span Buildings
- Curtains - Agriculture
- Curtains - Gymnasium
- Curtains - Truck Side
- Roller Doors
- Mattresses
- Pergolas
- Pool Covers
- Pools
- Screens
- Shades/Tension Structure
- Shelters Structures
- Signs
- Tarpaulins/Covers
- Tents
- Digitally control all welding parameters with our easy operation touch screen
- Vacuum track for accurate placement of materials
- Laser lights for precise alignment of images
- Digitally controlled traversing head for consistent application
- Tables to reduce and simplify material handling
- Operator side trough for rolled or pre- cut panels
- Can be built to various lengths to fit any company size, application or printer specification
- Equipped with rotary cutter for cut to length applications
Optional Add Ons:
- Eyelet Machine - Easyslide Grommet
- Ultrasonic Cutter
- 400 Volts - Three Phase (5 wire) - 50 Amp.
Air Requirements
- 7cfm @ 120psi
- Approx. 10kW
- 730˚C (1,350˚F)
Throat Width
- 3m (118") (Up to customer specification)
- Width: 1.2m (47")
- Length: 3m (118") (Up to customer specification)
- Height: 2.5m (98")
- 1,360kg (2,998lb)
- 6-50mm (0.25-2")
- Up to 15 seconds*
* Depending on the application, the seam width and the type of material used
