T300 Extreme Edge
Benefits of the T300 for a Sign Shop
Weld PVC, Vinyl, Acrylic and more
Why choose Welding for your Banners & Signs?
Easy & Profitable Banner Heat Welding Machine
T300 Extreme Edge
The Fastest Welder for Finishing Banners and Signs
Miller Weldmaster T300 Extreme Edge banner and sign welding machine combines versatility with precision adjustments. The T300 Extreme Edge can finish a 4ft x 6ft banner in under one minute!
- Aerospace
- Banners
- Screens
- Signs
- Quick- setting recall with touch screen and recipe storage of 25 memory settings
- Increased product efficiency with dual arms to configure straight seams
- Quick, repeatable, precision- head adjustments
- Available in hot air, hot wedge or both for product versatility
- Multiple seam configurations with quick, easy guide change
- Can be customized to fit your exact specifications
- 208-240 Volts - Single Phase -25 Amp.
- 380-400 Volts - Single Phase -16 Amp.
Air Requirements
- 5cfm @ 100psi
- Approx. 6kW
- Hot Air: 730˚C (1,346˚F)
- Hot Wedge: 450˚C (842˚F)
Throat Width
- 0.88m (34.5")
- Width: 0.6m (23")
- Length: 1.5m (59")
- Height: 1.5m (59")
- 231kg (510lb)
- 10 to 50mm (0.5 - 2”)**
- Up to 30m/min (100ft/min)*
brochures
pre-install info
