Texsew Pro Series
Solent Texsew Pro
Solent Tesxew Pro with auto insert and cut
Texsew Pro Series
For high speed, pucker-free seaming of all soft signage and sewn digital print finishing.
Now you can choose to start with the basic components then upgrade later when business grows and productivity and efficiency become even more important.
Start with the Solent Texsew Pro Basic and add the tooling and a conveyor to complete the set-up for the full Texsew Pro Conveyorline or the Texsew Pro Compact.
Single or twin needle sewing operations with fast changeover.
Reduced material handling makes it simple to use for all operators with minimum training required.
FEATURES:
TEXSEW PRO BASIC
- Durkopp Adler 827 sewing machine (German quality - made in EU)
- Nearly oil-free sewing head with minimum maintenance
- Fast changeover system for sewing guides
- Silicone / Latex edging guide (SEG)
- Automatic start and end tacking
- Automatic thread trimming
- Material edge detection - to automatically activate functions (back tack, tape cutter etc)
- LED sewing light
- Standard slack feed device with roll holder for Silicone / Latex keder edging (SEG)
- Adjustable height table
- Mounted on castors for easy movement around shop floor
TEXSEW PRO COMPACT
- All of the BASIC features plus...
- Conveyor synchronised with sewing speed which moves in both directions for easy handling of heavy or large fabrics
- 2,000 x 600mm Conveyor
- Textured belt covering
- Control panel for machine and conveyor functions
- Second pedal for conveyor return
- Special Solent system to allow sewing machines or Miller Weldmaster welding machines of different types to be linked with the conveyor, with easy changeover
TEXSEW PRO CONVEYORLINE
- All of the BASIC features plus....
- 3,000mm X 750mm Conveyor
- Rubber Grip Top belt covering
- Fully automatic sewing functions synchronised with conveyor
- Heavy duty slack feed device with roll holder for Silicone / Latex keder edging (SEG)
- Latex / Silicone / PVC auto cutter (SEG)
- Slack feed device with roll holder for feeding Velcro, webbing and tapes
- Velcro / Webbing / Tape guide
- Hemming guide x 1
- Emergency stop
- Special Solent system to allow sewing machines or Miller Weldmaster welding machines of different types to be linked with the conveyor with easy change over.
OPTIONS:
- Latex / Silicone / PVC auto cutter (SEG) - for Basic and Compact. Already included on Pro Conveyorline
- Solent auto tape insert (SEG) - Pro Conveyorline only (no retro fit)
- Puller feed for superior feeding of heavy fabrics and PVC - also assists in hemming softer fabrics All models
GUIDE OPTIONS:
- Single or double hem
- Pole pocket
- Beach / feather flag - for wide elastic and hem
- Custom guides for your product
SEWING MACHINE (ALL MODELS):
- Durkopp Adler 827-260122
- Twin needle lockstitch sewing machine
- Bottom feed and needle feed
- Needle distance 19mm (other sizes available)
- Auto footlift (pneumatic)
- Auto backtack (pneumatic)
- Auto thread trimmer (pneumatic)
- DLC coated needle bar and presser foot bar for nearly oil-free sewing
- CTB bobbins for constant thread tension and ruduction in bobbin spin
- max. speed 3,800 spm (depends on materials sewn)
- Max. stitch length 6mm
- Reflected infrared light barrier for automatic sewing stop at the fabric end with sequential functions for:
- seam end backtacking
- thread trimming
- sewing foot lift etc.
- Integrated sewing light (LED)
- Efka motor and control
- Steel stand with castors (height adjustable)
- Table top
- Drawer
- Compressed air requirement - 6bar
CONVEYOR UNIT (Compact and Pro only):
- Compact has textured belt covering
- Pro has rubber grip top belt covering
- Efka motor and panel control
- Pedal for high speed conveyor return
- Height adjustable
- Lockable Castors
