Twinner Ultra-HD
Twinner Ultra-HD
PROTOTYPE - Solent Twinner Ultra-HD - The world's only double needle 3 step, zigzag and straight stitch sewing machine
The most versatile machine ever that EVERY sail loft needs! Just 1 machine allows you to seam sails and finish UV strips, tapes and other parts of the sail.
Sew:
- 1 or 2 rows of 3 step zigzag sewing
- 1 or 2 rows of zigzag sewing
- 1 or 2 rows of straight stitch sewing.
With 2 needles, halves the time to sew sail panels and other 2 needle operations.
Saves valuable work space and increases productivity for all sizes of business.
- 700 x 220mm underarm clearance
- 2 needles - needle distance 16mm with interchangeable stitch types:
- 3 step (6 point) zigzag - 1 or 2 rows, 10mm stitch width, overall width 26mm
- zigzag - 1 or 2 rows, 6mm stitch width, overall width 22mm
- straight stitch - 1 or 2 rows, stitch length 4mm, overall width 26mm
- XXXL rotary hooks
- Safety clutch mechanism to protect hooks and enable easy re-engagement, without the need to reset timing
- Solent PL50 50mm puller feed (option for PL50x100, 50x100mm)
- Fully automatic lubrication by central reservoir
- 17mm footlift pneumatic
- Pneumatic foot pressure
- 4mm stitch length
- Sewing speed max. 600spm *
- Needle 140-200 system 7x23 or 794
- Thread size V69 to V138
- Needle cooler
- Stand with wheels and Efka DC motor and control
* depends on materials sewn
Related products
Twinner
Solent Twinner double needle 3 step zigzag sewing machine for sewing 2 symmetrical rows of 3 step (6 point) zigzag simultaneously. Halves the time to sew sail panels.
Twinner-W
Solent Twinner wide double needle 3 step zigzag sewing machine for sewing 2 symmetrical rows of 3 step (6 point) zigzag simultaneously. Halves the time to sew sail batten pockets etc.
Conveyorline-3S
New to the Solent range, the Conveyorline-3S - can be added to most Solent models for improved material handling capabilities and reduction of operator fatigue.
